cracked diesel head.
发表于 2021-9-1 00:34:47 | 显示全部楼层 |阅读模式
I have a 3 cyl kubota diesel with a crack in the center cylinder of the head..appears to be a surface crack, I am certainly not capable of welding it...does anyone know of a shop in eastern virginia that can do an oven weld repair on something like this, in addition to giving it a stock valve job after?I would just buy a new head, but 700 bucks per, I don't have the cash to sink into what is basically a free skid steer...Lincoln Weldpak 100Miller Maxstar 150Cutmaster 82Victor OA torch set...somewhere around here...
Reply:Even if you have to pay $1000. to get it fixed,............A $1000. skid steer is a good deal."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:true....but I don' got right now...Lincoln Weldpak 100Miller Maxstar 150Cutmaster 82Victor OA torch set...somewhere around here...
Reply:I usually charge 400 to repair with valve job, pressure test, and surface. Most of the production welding shops charge more. I have been quoted 900-1200 from local dealers for new heads. May be higher here?  For 700 (if it is NEW) I would get a new one, swap parts from old head. They come bare. Try to determine cause of overheating and repair problem too.Peter
Reply:Originally Posted by castweldI usually charge 400 to repair with valve job, pressure test, and surface. Most of the production welding shops charge more. I have been quoted 900-1200 from local dealers for new heads. May be higher here?  For 700 (if it is NEW) I would get a new one, swap parts from old head. They come bare. Try to determine cause of overheating and repair problem too.Peter
Reply:rebar through the radiator. nice
Reply:Originally Posted by jasonstewartrebar through the radiator. nice
Reply:Ok...so..this thing will cost 700-900 bucks either way..unless I get lucky and find a salvage engine, or get creative and adapt something..right..I'm gonna strip this head down, hot tank it, grind out this crack, put up a little furnace, preheat and weld the damn crack...it appears fairly shallow, and isn't in a wierd place...got not much to lose here...gotta guy at work will true the gasket surface for me and pressure test...might have to go get a valve job...or might check and see if the local high school had a valve machine..god knows I did alot of free valve work when I was in high school...This ought to be fun...Lincoln Weldpak 100Miller Maxstar 150Cutmaster 82Victor OA torch set...somewhere around here...
Reply:Have you heard of stitching pins.  These may be a DIY alternative, especially if the crack doesn't run across an injector seat or a valve seat.  I would do a dye penetrant test to determine the full extent of the crack before continuing with any method.[ame]http://www.youtube.com/watch?v=Pq0wfU4ZaKk[/ame][ame]http://www.youtube.com/watch?v=FIKY--USk7Y[/ame]Last edited by 76GMC1500; 03-31-2010 at 12:13 AM.
Reply:Originally Posted by zopiOk...so..this thing will cost 700-900 bucks either way..unless I get lucky and find a salvage engine, or get creative and adapt something..right..I'm gonna strip this head down, hot tank it, grind out this crack, put up a little furnace, preheat and weld the damn crack...it appears fairly shallow, and isn't in a wierd place...got not much to lose here...gotta guy at work will true the gasket surface for me and pressure test...might have to go get a valve job...or might check and see if the local high school had a valve machine..god knows I did alot of free valve work when I was in high school...This ought to be fun...
GMT+8, 2025-12-21 19:11 , Processed in 0.659835 second(s), 19 queries .
