Another Dozer Arm..
发表于 2021-9-1 00:34:44 | 显示全部楼层 |阅读模式
This arm has a new sleeve made for it..My boss made the sleeve and installed the new bushing and the snap rings to hold it in..Then Shrunk fit it into the arm bore..But the weld area has to be really small so the outer seals will press in without any added machine work..Not much there..But thats enough for me..The weld is small and flat and the seal fits just like its supposed to..I get all the fun jobs... ...zap!Last edited by zapster; 01-22-2007 at 06:02 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice JOb zap!How many amps where u running?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Originally Posted by elvergonNice JOb zap!How many amps where u running?
Reply:You get all the easy jobs.  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Looks like good work as always.
Reply:nice job.... as I would expect!_________________Chris
Reply:did you weld that continous or weld a little and let cool?
Reply:Originally Posted by lpscottdid you weld that continous or weld a little and let cool?
Reply:That dime thing looks good nice work...Strive For Perfection
Reply:I always worry about that stuff just haven't done enought of it yeat,thanks. scott
Reply:Originally Posted by BrooksThat dime thing looks good nice work...
GMT+8, 2025-12-21 19:16 , Processed in 0.097885 second(s), 18 queries .
