Finally fired up stick welder
发表于 2021-9-1 00:34:42 | 显示全部楼层 |阅读模式
Well I finally recieved my stick welder attachment for the precission 225.  Man stick seems alot easier then tig for sure.  here are my first two welding with the stick.  I'll post some more probably tonight or tomorrow.1/2in angle iron.  The piece seem to hold together really stong.Filling in a joint between two piece.  I was even surprised by it almost being completely level with the joint.  The piece had rounded edges.  Ignore the other weld that is vertical.  that was my friends weld.   I still working on him but its hard to train someone when you forget your spare helmet at a fab shop.  So it was let him weld then give him some tips here and there.  Today that should be better since I will have my auto helmet back.Figured I might has well get pratice in before we do this in my welding skills class and before I break **** while 4wheeling.Last edited by duc; 01-27-2007 at 10:08 AM.
GMT+8, 2025-12-21 19:15 , Processed in 0.157602 second(s), 18 queries .
