Another Plasma Cutting Jig
发表于 2021-9-1 00:34:40 | 显示全部楼层 |阅读模式
I didn't want to hijack Jonnie's thread on his plasma jig, but I had mentioned somewhere that I had made a prototype dedicated 45* plasma cutting jig. I had originally made out of wood and it was pretty clumsy, so I went ahead and made it out of metal.This jig works great for quick clean cuts with almost no cleanup. It makes open-ended 45's for making quick clean box frames. For maximum strength, I think notched-corner frames may be better.  The reason I like using the plasma is to minimize the noise factor in my yard where I work outdoors.  No cut-off saws and much quicker than bandsaws with the same results.I made it double-ended to provide for the left and right cuts.  Also, I made it magnetic to eliminate clamping, although they can be used if necessary for other metals. I  used a 6-pak of ceramic disk magnets I found at the Ace hardware for $2.79. It will do up to 2" stock and if stout enough to toss around without altering the angle.  All I do is slap in on at my mark, minus a 1/2" the set back for my gun.  I've found I get the cleanest cuts are by making the 90* first and then finish with the 45*. Attached ImagesHobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Rick, very simple, very clever, thanks
Reply:Dammit!! Where was this post when I was building 5 huge sign frames for Victory Homes last month!!!Great idea Rick.http://all-a-cart.comWelding Cart Kits and accessories
Reply:like the magnet idea.. sweet.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Very cool tool. I enjoy making my own tools, jigs and guides. Thanks for sharing the great idea'r. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Nice Job!...No worries on hijacking, I love seeing what people are using to make their jobs easier. I am going to post up some pics of mine in action per Zaps request."If you live in Sacramento you have seen my work."
Reply:Oh dude, that's cool! I may have to have one for every angle up to 90...crap! Another welding project.Ronnie LyonsMeridian, Idaho
Reply:You think something like that will work on square tubing also ? Because I was working on a bar stool racer frame and trying to cut angles without a chop saw was tough.Last edited by Steelwill; 01-27-2007 at 11:36 PM.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Thanks for the positive responses to the jig. It could be used for square stock, but it isn't very practical.  It would involve making three different cuts & repositionings of the jig which may lead to errors.  In that case, you're probably better off with a cut-off wheel or bandsaw.Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:looks good!Freelance Fabber91 GMC 3500 Portable welding truckLincoln Weldanpower 8000 gas welderMiller CST 250 Smaw/Gtaw inverterMillermatic 210 gmaw line welderHyperterm plasma
Reply:Originally Posted by Rick MoranThanks for the positive responses to the jig. It could be used for square stock, but it isn't very practical.  It would involve making three different cuts & repositionings of the jig which may lead to errors.  In that case, you're probably better off with a cut-off wheel or bandsaw.
GMT+8, 2025-12-21 19:10 , Processed in 0.107561 second(s), 18 queries .
