Small Project..DJ cage/Booth modification
发表于 2021-9-1 00:34:33 | 显示全部楼层 |阅读模式
I bounce at this club on weekends. I have done a lot of railing and other metal work at this club. However when the DJ cage was built and designed by another company they did not think upon the entry and exit design. The DJ would have to climb over the built in couches in the VIP section (other side of picture). So on the picture side you can see the dance cage I made a while ago and the owner finally asked me to cut a section out and reframe it back in. The entryway does not line up because he did not want me to re-do ($$) the steel shelving that holds the electronics. So I had to offset the hole.Not the "look" I wanted but that is what the owner wanted ($$). It is just function to get in and out.T.J.Last edited by TJS; 01-29-2007 at 08:36 AM.
GMT+8, 2025-12-21 19:10 , Processed in 0.092670 second(s), 18 queries .
