linde power pack hda 200 questions
发表于 2021-9-1 00:34:24 | 显示全部楼层 |阅读模式
where can i find a manual or info on this welder. it wont create a pilot arc.if i scratch or lift arc it then it works fine. where can i go or what can i do to get started on getting this working right. thanks for the help.millermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:Go to ESABNA.com, they bought Linde and will have the manuals.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:thanx ill post what i find. thanx againmillermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:esab does not handle linde any more. what i found was arc product at http://www.arcproducts.com has been contracted to handle all that old stuff they have a manual you can buy for $16 and some change and they will email it to you and if you need more info rj kates at 1-858-505-8321 gave me some info that was very helpfull. hope what i found in my long drawn out search  will help all of you so you dont have to go through what i had to.millermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:Arc Products handles PowCon too.  They're down here in San Diego.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:oh i just got the new tank hooked up and tried it out and it works really good. i do still need a certain part to finish it up but that is all. i need the phase shift rheostat switch mine has a bad spot in it so if any one knows where i can get one i would appreciate it. thanksmillermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:Originally Posted by eyepoppin customsesab does not handle linde any more. what i found was arc product at http://www.arcproducts.com has been contracted to handle all that old stuff they have a manual you can buy for $16 and some change and they will email it to you and if you need more info rj kates at 1-858-505-8321 gave me some info that was very helpfull. hope what i found in my long drawn out search  will help all of you so you dont have to go through what i had to.
Reply:I just baught a HDA-200 for $200 bucks!!! But it's missing the foot pedal. I looked up the model number on the stock foot pedal and it was FC-2 131B21 or FC-2S 131B22. Does anyone know the difference? I would like to go after market if I could. Is there any aftermarket foot pedals that will work for this welder? Oh, and thanks for the link to the manua on the ESAB site!!!Thanks,Jim
Reply:HDA-200  & HDA-300 Manual -http://www.esabna.com/literature/Arc...R_SUPPLIES.pdf
GMT+8, 2025-12-21 20:56 , Processed in 0.190814 second(s), 18 queries .
