parts needed
发表于 2021-9-1 00:34:23 | 显示全部楼层 |阅读模式
OK all of you have helped out so much with all the questions me and everyone has had, so i will say thanks in advance for the advice. OK here is a hard one i am looking for a phase shift rheostat OEM p# 280Z22 for my linde power supply hda 200. i did some goggling and think i found a cross referenced p# of 5905-00-761-8719 but i cant find out if this is for sure the one i need or not. i am also looking for OEM p# 9579F81 f1 spark gap assembly. and any of the hi freq parts. thanks to you guys on here i have gotten the full manual on my machine and have worked out most of the issues i had and have gotten to use the machine a lot i just want to be-able to fine tune it a little bit more. sorry about the long post. thanks againmillermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:Was ESAB no help, if so Call Applied Equipment in Dallas Texas, Larry will probably have them in stock.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:esab no longer deals with that old stuff a company called arc products handels the manuals but thats it. ill let you know what applied eduipment has to say thanks alot.millermatic 210miller 375 xtreamlinde power supply hda 200 tigcentury 110 flux corelincoln buzz boxlet the work speak for itself i do!!!check mine out at http://www.eyepoppincustoms.com
Reply:need: Foot pedal for a Linde HDA-200 the part # is FC-2 131B21 if anyone has one, or another product that is compatible.Thanks a bunch
GMT+8, 2025-12-21 19:33 , Processed in 0.069902 second(s), 18 queries .
