More Precision With A Tig...
发表于 2021-9-1 00:34:21 | 显示全部楼层 |阅读模式
In the days before we got the tig machine we'd just take some 7018 and blast away on journals to build them back up..But 9 times outta 10 you'd ruin threads/keyway slots if the journal was small enough and that ment re-threading..Re milling key slots..lotsa work..But with the amazing tig machine we now can save threads..keys without the hassell of covering everything up and praying.. Heres this A.M. save.. Huge rubber roller with tiny (for its size) journals..This makes it so easy now..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice Zap!Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:Yes sir..... it makes it sooooo much nicer when you have to create any more work than you need to._________________Chris
Reply:the guy who I learned tig from always said "like a sculpter adding clay" a rather poetic way to put it but so true.  You always do nice work zap
GMT+8, 2025-12-21 20:56 , Processed in 0.102625 second(s), 18 queries .
