Lincoln Hobby-welder any good?
发表于 2021-9-1 00:34:14 | 显示全部楼层 |阅读模式
Hello gurus.Can someone please tell me if this type of welder is any good for the beginner welder.Is this a good price for it?  Thanks a lot.http://www.buysell.com/root/detail/M...pment+Serviceshttp://cdnppgmedia.hometrader.ca/ppg...?W=1600&h=1200
Reply:Depends what you plan on doing. These things are pretty mickey mouse. You should keep your eyes peeled for a Lincoln Tombstone (AC225) You will be able to do a lot more with it but you will need 220V. They can be had for around $200.
Reply:Originally Posted by salem747Depends what you plan on doing. These things are pretty mickey mouse. You should keep your eyes peeled for a Lincoln Tombstone (AC225) You will be able to do a lot more with it but you will need 220V. They can be had for around $200.
GMT+8, 2025-12-21 19:33 , Processed in 0.069944 second(s), 18 queries .
