Can You Fix This Pleeezzzzzzzeeeee?
发表于 2021-9-1 00:34:09 | 显示全部楼层 |阅读模式
Ahhhhh Here we go again.. Snowmobile Heat Exchanger..If you dont know what it is..Its a Radiator..sorta..These are found in the back up underneeth in a snowmobile thats liquid cooled..(My Mach Z has one)But they dont have fins..Its basically an Aluminum box that water comes in one side..out the other..no baffles or chambers and the snow you throw up off the track does the cooling...Ok Enough of that..Here it is..Notice its "steaming"..this is after cleaning the outside..but you must pass the torch over it a few times because it had antifreeze in it and one way or another it's gotta go..Here is one crack..heres two more..First pass..First pass over the two..OK Now on to the next post.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:After the water/pressure test..It was thumbs down.. Unwilling to admit defeat..Its time to stitch it and get it over with..Results..Holds water and pressure now.. Heres the weapon...3/32 red Gas mix..80 Amps..4043 1/16 filler..I get all the fun jobs..And by the way..Do not pay attention to any of the other "welds" you may see..I have NOTHING to do with themThey are awful.. ...zap! Attached ImagesI am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice. Although the first welds don't look up to your usual level of excellence, I'm guessing that's due to the material and not the operator. Good job.EDIT: hehehe, I just criticized Zap's welds.....that's kinda funny.
Reply:Originally Posted by jknight8907Nice. Although the first welds don't look up to your usual level of excellence, I'm guessing that's due to the material and not the operator. Good job.EDIT: hehehe, I just criticized Zap's welds.....that's kinda funny.
Reply:Ya, it looks to be crumpled up quite a bit. I was repairing a roof snow rake yesterday and it was hard to get the correct angle on the material.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:great stuff, thanks zap.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Nice work Zap.  Looks like you're always willing to take on the jobs that others may pass on.  Tenacity is a virtue that's hard to find nowadays  Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Dapper Zapper lives in Massachusetts, not Tenacity.  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneDapper Zapper lives in Massachusetts, not Tenacity.
Reply:John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-21 19:31 , Processed in 0.087923 second(s), 18 queries .
