I guess we won't be seeing these characters on our "Projects" list anytime soon
发表于 2021-9-1 00:34:04 | 显示全部楼层 |阅读模式
Musta been amateurs, if they couldn't hide the welds.... news item from Wednesday:Auto workers find hidden pot in gas tankWed Feb 21, 11:04 PM ET ST. PAUL, MN - A couple from Washington state faces charges after auto workers found more than 150 pounds of marijuana in their pickup‘s jerry-rigged gas tank and alerted police."Their bad luck is their vehicle had some fuel problems and they ended up taking it into a Midas Shop," Bailey said.At the auto shop on the East Side, where the couple stopped Monday, mechanic Daniel Ries noticed the truck had a modified gas tank with fresh weld marks. When the two were told the tank needed to be replaced, they were "adamant" that the repair wasn‘t needed, Bailey said. Eventually, they relented but insisted that the pickup‘s old tank be saved.Bailey credited Ries for recognizing something was suspicious. "That‘s exactly what we need, because we don‘t have enough law enforcement to cover every corner," he said. "It was absolutely sharp thinking."Last edited by RichardWDF; 02-23-2007 at 02:00 PM.
Reply:We had a similar case here where a guy had a second gas tank in his F-150. Cop found a couple pounds of coke in it.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
GMT+8, 2025-12-21 19:36 , Processed in 0.091004 second(s), 18 queries .
