Got the "toy"..Needed "modification"..
发表于 2021-9-1 00:34:03 | 显示全部楼层 |阅读模式
Got the weld positioner that I won from E-bay today..Came as advertised..Everything works like it's supposed to..Out of the box..Needed one of these...20 Minutes later..Done!  Now I need something round to weld.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It looks like the chuck is going to pull off the turn-table. To me, it would seem the chuck is too heavy for it, what are its weight capacities?I'm sure others are going to ask, thats why i'm asking. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by zapsterNow I need something round to weld.. ...zap!
Reply:Thats not going anywhere.. I had the exact same positioner where I used to work..And I had mounted a much bigger chuck on it than that..Still worked just fine 5 years later...So Myself?I'm not concerned.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:And the positioner will spin 400.....500 LB. rollers with little effort as long as the roller is on rollers on the other end.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Roger that Zappo, figured i'd ask...thanks!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Zap, have you looked inside to see how the rotational ground is configured? Some simple positioners have a simple spring tensioned braided copper strap wrapped around the main shaft.
Reply:Originally Posted by pulserZap, have you looked inside to see how the rotational ground is configured? Some simple positioners have a simple spring tensioned braided copper strap wrapped around the main shaft.
Reply:Now thats a cool setup (for the price).Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Was using one myself today.Had a small run of sprockets to weld hubs to.This one is stationary with an air powered hold down clamp and exhaust hood.   This is the other one I use,with a new fixture on it.They built this fixture because the anal retentive inspector thought the old one had a little to much wiggle room.This is the first test piece,to figure out positioner and welder settings.Well,hehehe,after running the test beads,went to remove that big solid round piece,NOPE....IT`S STUCK HAHAHA.Thats what they get for replacing something that didnt need to be. Darwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
Reply:Nice set up!Mig welds ..Very nice!Dont stay grumpy..Get over it.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice Rob!
Reply:Hey Zap we used one of those positioners to weld ring gears to fly wheels!  Theyre pretty nice.
Reply:Originally Posted by Dipper Welder64Hey Zap we used one of those positioners to weld ring gears to fly wheels!  Theyre pretty nice.
Reply:All work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boyAll work and no play makes Jack a dull boy...http://all-a-cart.comWelding Cart Kits and accessories
Reply:how much did it set ya back?Jason www.Z28.comOwner/Admin
Reply:Originally Posted by MasterZhow much did it set ya back?
Reply:Rob, nice mig weld on the sprocket.Conventional spray transfer or a pulsed spray?
Reply:Originally Posted by zapster450$ plus shipping..I stole this thing.. ...zap!
Reply:Firstly,sorry for the thread hijack Zap.  Secondly,thanks for the kind words Zap,Dipper Welder64 and Pulser.   Pulser,it`s just conventional transfer.The machine I use is a Miller-matic 350p running on 480 volts(atleast thats what it says on the outlet)settings were,arc length 50,wire speed 310,.045 ER-70s-6 thermal arc wire,Tri-mix gas(argon,carbon dioxide,oxygen)   What the heck,might as well hijack a little more. This is job I started today,after the fiasco with the above mentioned fixture,we switched back to the old ones to get the job done.Settings were the same except for wire speed,which was upped to 350 ipm.Darwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
Reply:Nice welds Rob....._________________Chris
Reply:Well I'm back and the shoulder stayed where its supposed to this time out!  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-21 19:40 , Processed in 0.131611 second(s), 19 queries .
