I have and All Star welder model 117-002 that will not feed the wire through when i pull the trigger. I can manually advance it and i here the contacts activate when i pull the trigger. Can anyone help?
Reply:With the machine on, release the drive roll tension and pull the trigger. Does the drive roll turn and change speed with changes in wire speed setting? If not, either the drive motor is not getting power, or the motor is burned out. Check for power at the motor connection with the trigger pulled and wire speed setting on high.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op |
