Running welder on batteries
发表于 2021-9-1 00:33:55 | 显示全部楼层 |阅读模式
Hey I was just wondering if i could run my lil 140amp stick inverter off 3 12v battiers i will be using 2.4m rods to burn through a mates container lock on his farmThanks steveCigweld Transmig 265seBoc 140amp StickBoss 200amp AC/DC TIGLincoln Electric Invertec V260-S
Reply:Really doubtful.
Reply:You'd need a 12vdc to 120vac inverter that can provide 15-20 amps of ac power and enough battery bank to draw from.   Would be cheaper/easier to just buy a used 4KW or more portable generator.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Unless your machine was designed and made to accept DC input power, no.But you can, to a certain extent, weld using big batteries as the power source (aka 'welding machine') all by themselves.  Hook up the batteries in the desired configuration and put some welding leads on things.  Stick weld away.  Not all that controllable and no real way to 'adjust' the settings, but you -can- stick weld that way.One battery is not enough volts usually.  Two batteries in series is more appropriate for 'smaller' diameter electrodes.  Three batteries in series is usually enough volts to use most 'common' electrode sizes.  Make sure all wiring and interconnects are appropriate for welding currents. as vehicle batteries can dump H-U-G-E amounts of current if given the chance (like a short circuit, so don't stick the rod eh?    )  Running a loop of welding cable around a chunk of iron/steel pipe as a big inductor may help to smooth out the arc.  YMMV.Just trying to burn through something with a stick electrode?  Yeah, 3 '12volt' vehicle batteries in series can do that.  The best laid schemes ... Gang oft agley ...
GMT+8, 2025-12-21 19:40 , Processed in 0.091815 second(s), 18 queries .
