Fittings That Do Not Exist....Yet
发表于 2021-9-1 00:33:52 | 显示全部楼层 |阅读模式
Had a custom A/N Fitting weld job to do this A.M.Fitting (In 2 pieces)..Make the fitting to the drawing...Ok so that was E-Z.. What else can we make???...zap!Last edited by zapster; 03-03-2007 at 11:45 AM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice job zap.I've been there before. Tight space, no fittings available that will work...cut one up and make it!!  - Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Should'nt you be getting ready for school???  Tell everyone I said HI!Have fun!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Zap-what rod did you use and at what amp?nice jobbie,cheers,C.Idealarc 300\300 TIG AC\DC
Reply:Why are they called A/N fittings?I would call that a JIC male to male Pipe.
Reply:Thats cool.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by ChenSZap-what rod did you use and at what amp?nice jobbie,cheers,C.
Reply:It stands for Army/Navy...or some say Air Force/Navy. An excerpt from WIK - "The AN thread is a particular type of fitting used to connect flexible hoses and rigid metal tubing that carry fluid. It is a US military-derived specification stemming from a joint standard agreed upon by the Army and Navy, hence AN. However, some documents say the name is really Air Force/Navy."John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Thanks!!Well now we all know... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Welcome, just trying to help...as I type from my WI-FI enabled PC in the shop.  So many acronyms, so little time. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:good job, but they make a fitting like that. aeroquipt makes it i believe, you can get 120 degree or 150 degree..cant tell what that is from the pic.
Reply:What size -AN fitting was that Zap?I just want to know how good you really are, lol.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:looks like a -8 to -12.. or a -6 to -10
Reply:Originally Posted by Patriot PerformanceWhat size -AN fitting was that Zap?I just want to know how good you really are, lol.
Reply:i hope the customer had you make a few of them. no need in making a 1off unless it's a prototype."Retreat hell, were just fighting in the other direction"Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun  Hypertherm 1000Lincoln sp 1702000 F-450 to haul it
Reply:Originally Posted by backuproller...no need in making a 1off unless it's a prototype...
Reply:Originally Posted by terr1bleonelooks like a -8 to -12.. or a -6 to -10
Reply:I'm thinking it's a Saturday, either the customer didn't bother to look around for the specific angle or it was just more convenient to have the Zapster give it a ZAP.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneIs that a single guess...or a range?
Reply:Sorry guys..The "customer" already has the fitting in his possesion..Its going into a water cooled turbo "Pro Charger" made by Vortex..Thats all I know right now..The bigger end was about the size of my thumb...Smaller one..Pinkey finger..Scale those dimentions out...  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Fitting looks like SS.5356? Not.
Reply:Sorry again for the slow thinking....WHAT ARE THOSE FITTINGS MADE OF EXACTLY???Idealarc 300\300 TIG AC\DC
Reply:Originally Posted by ChenSSorry again for the slow thinking....WHAT ARE THOSE FITTINGS MADE OF EXACTLY???Originally Posted by pulserFitting looks like SS.5356? Not.
Reply:If you say so?  But I don't get it.Is the fitting stainless steel?Isn't 5356 aluminum filler?Something doesn't add up.Sorry, I'm just wanting to get this straight since there are apparently so many beginners who might actually believe you and not realize that maybe you made a mistake or perhaps a typo.I will continue to doubt you, and everyone else, including myself.
Reply:Originally Posted by pulserIf you say so?  But I don't get it.Is the fitting stainless steel?Isn't 5356 aluminum filler?Something doesn't add up.Sorry, I'm just wanting to get this straight since there are apparently so many beginners who might actually believe you and not realize that maybe you made a mistake or perhaps a typo.I will continue to doubt you, and everyone else, including myself.
Reply:You guys are both wrong, it's Unobtanium ! John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:So pulser......what material are these fittings made of? Attached Imageshttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by ZTFabSo pulser......what material are these fittings made of?
Reply:Originally Posted by MicroZoneWelcome, just trying to help...as I type from my WI-FI enabled PC in the shop.
Reply:Originally Posted by wallythackerGreat isn't it? Biggest diversion there is next to TV. I'm so hooked on access my shop plans have the wifi figured out already. Before even breaking ground.
Reply:Paul - those are Silver...as in Gold, Silver, Platinum.  What are those -3's ? A little of each eh, bulkhead fitting and all...nice!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Don't want to take a serious guess at it?http://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by pulserThe first one looks like oak to me, can't tell with the others.
Reply:Ok zt, ill bite.  Copper.  Thats my final answer.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by jknight8907*sigh* Somebody failed tree ID class.....those are obviously made of white ash. Hellooo!
Reply:Man, it's a good thing you guys are welders and not carpenters!!The fitting on the left is Spalted sassafras and the 3 on the right are Pernambuco.Anyone who know ANYTHING about wood could tell you that based on the grain structure.....geesh.http://all-a-cart.comWelding Cart Kits and accessories
GMT+8, 2025-12-21 19:36 , Processed in 0.101738 second(s), 18 queries .
