Todays Shaft Build-Up
发表于 2021-9-1 00:33:52 | 显示全部楼层 |阅读模式
I just love  the positioner..Being able to weld a whole shaft without stopping has made me a happy ...zap!Here is the shaft in the positioner waiting for the Inevadable..Here's both worn out bearing landings..I'll do the other end in the A.M...Note in pic 1..There is a black thing on the shaft..Thats called a magnet..So I'm assuming the shaft is steel..Not aluminum..Not stainless..There has been discussion lately about if I know what anything is made out of...Or if I'm welding the "right" stuff with the "right" filler wire.. I'm pretty sure I need 70S-2 for that..OOPS!! Too late..One side has been done already..   Thats my story and I'm sticking with it!!...zap! Attached ImagesLast edited by zapster; 03-05-2007 at 04:33 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:The fitting is Aluminum..Here's the end thats done.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looking good.  Are you thinking about a TIG wire feeder yet?You know, with a nice machined cylinder like that, you could clamp the torch (with wire feed) to a cross slide at a fixed arc length, and jog the torch over to the toe line every 360 degrees.
Reply:If He didn't have to weld it himself He would be so bored that the posts would triple from shear boredom lol Zap!
Reply:How many thousandths over the turned size zre you?_________________Chris
Reply:Originally Posted by lorenzoHow many thousandths over the turned size zre you?
Reply:super nice multi welds!!!Idealarc 300\300 TIG AC\DC
GMT+8, 2025-12-21 19:40 , Processed in 0.070716 second(s), 18 queries .
