Motorcycle Catch Can
发表于 2021-9-1 00:33:52 | 显示全部楼层 |阅读模式
Catch can fabricated out of aluminum for a supermoto bike. 1/8 inch aluminum tube, 1/8 inch plate for the ends. Tapped tube fitting for clear drain hose. I drew a yellow box around the welds as they are hard to see, (this is a welding forum!) 3/32 red tungsten - 135 amps, pulse, no filler. - Lincoln PT 185. - Only downer of the whole thing was not having a rotary table. Starting, stopping, then turning the piece sucks. Attached ImagesLast edited by kshellrazor; 03-05-2007 at 12:38 PM.
Reply:Looks good from what I can see. I've made a few catch cans myself. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:They don't let you just dump the crankcase vent and fuel overflows on the track?
Reply:Originally Posted by 76GMC1500They don't let you just dump the crankcase vent and fuel overflows on the track?
Reply:When's you're next shot at the track and where?
Reply:Only downer of the whole thing was not having a rotary table. Starting, stopping, then turning the piece sucks.
Reply:Originally Posted by zapsterI feel for ya my friend...I did the same thing for a long time... ...zap!
Reply:Originally Posted by kshellrazorZap, saw your table - NICE!! How do you control the speed of the Rotary table?
GMT+8, 2025-12-21 19:35 , Processed in 0.075804 second(s), 18 queries .
