Rotary Welding Table
发表于 2021-9-1 00:33:44 | 显示全部楼层 |阅读模式
I'm wanting to build an automatic power rotary table.  Does anybody have any ideas?  Is for a production job 60 pcs. every month or so.  It's 2 halves of 1/8" steel that has been metal spun like hubcaps 36" dia.  Plus some other stuff 2-1/2 & 6" dia.  Any advise?
Reply:First thing to mind is a potters wheel type thing. Rotate with yer feet or hook up a motor...or hamster....or small child, what ever you have lying around I'm here all week,folks....Can the pieces just sit on the table or are they needing to be clamped down?  Do you want to get fancy or go farmer with it?Bert200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Try a search.  Here is one previous thread I found.http://weldingweb.com/vbb/showthread.php...ght=positioner
GMT+8, 2025-12-21 19:40 , Processed in 0.085368 second(s), 18 queries .
