1/7th rule for acetylene tanks
发表于 2021-9-1 00:33:44 | 显示全部楼层 |阅读模式
Would a #7 tip from the Smith Little torch kit break the 1/7th draw rate rule of an MC sized acetylene tank? A Smith Little torch #7 tip would be similar to the Victor #2 or a Smith AW206. Thanks...
Reply:The instructions should give you the info, if not then go to their web site.
Reply:Yes it would.  JGSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Thanks for the replies and info, much appreciated guys. I picked up a set of tanks today, I went with a 40 acetylene and a 60 oxygen which I think should do the little jobs that pop up in my home shop every now and then just fine.
GMT+8, 2025-12-21 19:34 , Processed in 0.095674 second(s), 18 queries .
