查看: 13|回复: 0
Roundy Round welding..
发表于 2021-9-1 00:33:43 | 显示全部楼层 |阅读模式
Nothing special todayJust Round stuff..4 of them..Bushings into the plates then the plates into the roller..I get all the fun jobs...  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice welds.Did you know, in Australia, they rotate the part in opposite direction?
Reply:Originally Posted by pulserNice welds.Did you know, in Australia, they rotate the part in opposite direction?
Reply:I just sit on the other side of the bench...  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:When you are using your rotator are you setting the speed at a constant setting and welding or are you welding and as you near a point where you want to rotate the piece you do so and continue that way?_________________Chris
Reply:You get all the roundy-round jobs ! Nice work.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by lorenzoWhen you are using your rotator are you setting the speed at a constant setting and welding or are you welding and as you near a point where you want to rotate the piece you do so and continue that way?
Reply:Nice Job Zap!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
GMT+8, 2025-12-21 19:40 , Processed in 0.081017 second(s), 18 queries .
