Were can I get a short piece of 16" inch tube?
发表于 2021-9-1 00:33:41 | 显示全部楼层 |阅读模式
I need a piece of 16" diameter tube for a concrete form only needs to be about 2 inchs long. Im sick of cutting up sona tube each time so I want to make a steel form. ID can be +- an inch so it doesnt need to be exactly 16". Any ideas?
Reply:try a scrap yard, you should be able to buy what you need by the pound
Reply:Why not make one out of 2"x 1/8" flat stock? Find something 16 inches in diameter and bend it around it.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneWhy not make one out of 2"x 1/8" flat stock? Find something 16 inches in diameter and bend it around it.
Reply:Check the furnace piping section at your local home depot or Ace hardware. There is bound to be something that diameter.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:There is a piece of 15.5 OD tubing 3"tall with a (about) 3/8" wall thickness on the floor of the shop (I saw it this A.M. when I thought of this post) that I'll give you if you wish..Just pay the shipping......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:A cheap harbor freight ring roller.  Some 1/8"x1-1/2" strap. make a form then wrap as Microzone suggested.  Or you can make many straps rings and stack and tack them together.  I believe the capacity is 1 inch wide on that roller, however I have rolled 1.5 width.  If you get too wide then it becomes conical as you roll.
Reply:Just use the 2" x 1/8" flat stock and make a round form with a 16" diameter out a piece of 3/4" wood, and for the metal around that.Only two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
Reply:tack some  scrap on your  welding  table  in the  circle you want..shouldnt  need  to  many  spots  for  thin materialor....i would  think  1/8 material would  bend  around a  decent  sonotube
Reply:what the diameter of a bbq grill propanr tank.just get some 1/8 x 2 1/2 flat and bent it around it.KISS...KEEP IT SAFE STUPID
Reply:Originally Posted by TIGBOYwhat the diameter of a bbq grill propanr tank.just get some 1/8 x 2 1/2 flat and bent it around it.
Reply:I would use something thinner, like 18 or 20ga. Easy to bend. you'll need a strip about 50" long.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:Originally Posted by ztecI thought about that but I cant seem to find much that is 16" in diameter. I would have to use sona tube and pour concrete into it and bend it around that which is probobly what I will end up doing. I was just hoping there was a place that might sell something already made.
Reply:I'm going to roll a piece of 20 ga. on my roller and send it to this chap.  I almost feel bad this thread has gone this long.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-21 19:35 , Processed in 0.065109 second(s), 18 queries .
