Smith's Gas Mixer
发表于 2021-9-1 00:33:39 | 显示全部楼层 |阅读模式
Well guys the mixer arrived today..so....naturally i had to "modify" it right away...it came with 3 inlets..argon..helium and CO2well i'm not using CO2 so i just "eliminated" the "unneeded" hardware inside...this is what i started with...front Attachment 4199rearAttachment 4200insideAttachment 4201see next post.....zap!Last edited by zapster; 12-27-2007 at 05:21 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:this is what i made it into now..inside..i had to drill a new "outlet" hole for the gas fitting..the output tube was not long enough for the stock hole...Attachment 4202front..Attachment 4203rear..Attachment 4204now i need some electricity and some water.. ...zap!Last edited by zapster; 12-27-2007 at 05:21 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks zap.  Ill keep my eyes open for another one of those.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:How did this old post end up here ....When I did'nt do it? ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That thing was $1200 ? Looks like nothing more than some fittings, a few regulators and a mixing cylinder.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneThat thing was $1200 ? Looks like nothing more than some fittings, a few regulators and a mixing cylinder.
Reply:Roger that. Is it simple enough someone can make their own ?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:I'm guessing each individual regulator is made specifically for that particular gas it has to process..I'm not sure..But that would make sence..Diffrent gasses are diffrent "weights" and thus would require diffrent spring weight requirements to function properly.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Regulators also have different internals, depending on the gases, because some gasses react with some of the pieces.
GMT+8, 2025-12-21 20:31 , Processed in 0.094043 second(s), 18 queries .
