What amperage are household Oven connector rated for?
发表于 2021-9-1 00:33:27 | 显示全部楼层 |阅读模式
Hello, can someone in the know here please tell me what (generally) are household oven/stove connectors wired up to handle what amount in term of amperage?  I just look at the stove wire that goes into the wall socket, and it appears quite thick.
Reply:50A (generally)
Reply:Another way is to look at the circuit breaker or look at the oven plug, there should be a NEMA number 6-50P, 250 volt @ 50 amps.http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
Reply:30 to 50A  10-6# wireHOBART IronMan 230 MIGSmith Lifetime WH200 HD O/A Torch
Reply:It probably varies a bit with jurisdiction. In Ontario Canada an oven receptacle is fused or breakered at 40 amps. A # 8 wire is run to it which is also rated at 40 amps. Why do you ask?
Reply:Find the circuit breaker that feeds your oven outlet and read the numbers printed on the breaker, that will tell you exactly what your particular circuit is rated for.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The oven/stove in my apt is a cheap pos and shares the kitchen 15A (110v) serivce. Ugh.hate electric anyway.gas > electric.
Reply:In the US a household range is supposed to be wired for 50A.IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
Reply:Originally Posted by r.manIt probably varies a bit with jurisdiction. In Ontario Canada an oven receptacle is fused or breakered at 40 amps. A # 8 wire is run to it which is also rated at 40 amps. Why do you ask?
Reply:Why not just buy the right plug to fit the outlet and wire that to welding machine's power cord?  That's how I do it if I'm only going to be connecting that machine to that outlet.  If I intend to connect the machine to different outlets, then I put a plug on the machine to match the outlet style I intend to use the most of and make an adapter (or multiple adapters) to fit whatever other outlet I want to use.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Why not just buy the right plug to fit the outlet and wire that to welding machine's power cord?  That's how I do it if I'm only going to be connecting that machine to that outlet.  If I intend to connect the machine to different outlets, then I put a plug on the machine to match the outlet style I intend to use the most of and make an adapter (or multiple adapters) to fit whatever other outlet I want to use.
GMT+8, 2025-12-21 20:32 , Processed in 0.070470 second(s), 18 queries .
