any suggestions to get started on my bbq smoker
发表于 2021-9-1 00:33:25 | 显示全部楼层 |阅读模式
My son has had the shop tied up with work on his boat.I am eager to get started on my smoker.The first pict, are of the cabinet I picked up for smoking.I thought the wall thickness was to thin for BBqing so I picked up the tank and want to either split in half and hinge it or just make a nice access door with a grate inside.I have a nice size cast iron woodstove for a fire box.I have seen some rigs that have firebox on one end with tank in middle then a simular enclosuer on the other end of tank with racks.Thus making use of both the tank as a cooker and the enclosure on end for smoking.I see most tanks just have a firebox welded right to the mane tank.Do you cut out the most of the end of firebox where it enters tank or do you just send in the smoke off of the wood stove outlet to chimney?
Reply:You need to show us some pics of this thing.  I have been thinking of building something like it.  Ive seen some good ideas here (much too large for what I need, but very nice).Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Sorry I thought the pictures were on first post. Attached Images
Reply:Looks like you have a great start with materials. I think it goes right off the firebox, through the smoke box, then out the chimney.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Thanks it is just sitting on the drop trailer so I can move it easy.I will be building a new trailer so it is alighned with firebox on right cooker tank in the middle and stainless  smoker on the opposite end.I am trying to decide if I should open one large door in the tank thus making grating installation easy.Or put two doors so you can just open either side without opening entire top.Or I could split the tank horrizontal and stiffen both halves with angle iron so it shuts flush.I have a large quantity of 1/4 x 1,1/2 flat bar to form and weld around the doors so they seal good if I decide to go with a door on hinges.Last edited by welditnow; 03-19-2007 at 03:19 AM.
Reply:I have built a few. It looks like you have a good start with materials. I will be glad to answer any questions you have or check this place for all things BBQ.http://www.thesmokering.com/forum/index.php
Reply:broncstomperThanks for the link.But as long as I caught you here for a bit do you think this propane burner would work to regulate the temp better.I then could either use wood from the fire box or just add some chips above the burner in a pan.I think I could regulate the temp better with propane.I will just make a cutout on the underside of tank thus keeping all propane lines on the outside of tank.http://www.northerntool.com/webapp/w...70_23798_23798
Reply:Who is gonna build me one?? ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Not ME ! John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneNot ME !
Reply:Welditnow,  That fire box is just that correct? It sure looks like a wood burning stove, if thats the case some of those things have a "Catylitic convertor"?? thing to help the exhaust be cleaner and to more effeciently (wrong spelling) burn the wood. If it has one I don't know what it would do to the meat or the tast. Just a thought. Looks like the only thing you need now is a pig a cow and some chicken.. Oh. alot of cold beer ready when the meat's done.
Reply:love the firebox man,good luck me and my son just built one and man was it alot of work.lots of fun also,good luck Attached ImagesLast edited by paintman; 03-19-2007 at 10:45 PM.
GMT+8, 2025-12-21 20:30 , Processed in 0.318650 second(s), 18 queries .
