spiral stair cases
发表于 2021-9-1 00:33:24 | 显示全部楼层 |阅读模式
does anyone have any information on how to get started to build a spiral stair case.
Reply:If you run a search, there was quite a long thread on it about 6 months back. There is a formula for figuring the rise/run around a circle. Very neat stuff, one of these days I'd like to build one.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:i can not seam to find the information you are talking about o th espiral stair cases
Reply:I did a search for you and came up with these: 1) http://www.weldingweb.com/vbb/showthread...=spiral+stairs2) http://www.weldingweb.com/vbb/showthread...=spiral+stairs3) http://www.weldingweb.com/vbb/showthread...=spiral+stairsJohn -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:thank you verry much .
Reply:Welcome, I hope that helped.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-21 20:31 , Processed in 0.093591 second(s), 18 queries .
