More stainless pipe
发表于 2021-9-1 00:33:16 | 显示全部楼层 |阅读模式
Stainless pipe Attached Images
Reply:again nice welding what amp's were you runing atand what type of gas cup do you use?ChuckASME Pressure Vessel welder
Reply:Looks good lets see some pics of the root passes, lets see what its made of.H2osStickers.comMiller Syncrowave 250 Hi-FreqMiller 252 migHypertherm Powermax105Miller Maxstar 200Hypertherm 1650Tourchmate 1   4' X 8'Hossfeld Bender30W Laser Engraver
Reply:Originally Posted by chopper5again nice welding what amp's were you runing atand what type of gas cup do you use?
Reply:Thats some nice stuff!I wish I had more stuff like that to do.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice welds--what are you making?
Reply:I'd like to hang one of those elbows on my wall....nice !  -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:very nice, looks like a machine weld.
Reply:Good looking welds. Its hard to tell from the pics but the color you want when finished is wheat. If it is darker than that you want to cool the weld prior to the cap with sprayed water. I have seen in the past inspectors will fail welds with too dark of a color. Keep up the good work and get your color perfect.
GMT+8, 2025-12-21 21:46 , Processed in 0.065648 second(s), 18 queries .
