spool adapter
发表于 2021-9-1 00:33:11 | 显示全部楼层 |阅读模式
I hope someone can help me on this. I need a spool adapter for my mig welder. it is a harbor freight duel mig 151. the first one that i had, had a spool adapter in it which would allow me to use 10 lb spools as well as 2 lb spools. the new one dosnt have one in it. It dosnt even show one in the parts diagram.  Most of the other small welders i have seen has on as well. do anyone know where i can buy one at? my local welding shop dosnt have one either. couldnt fine one on the miler or Lincoln site either.  HELP those 2 lb spools are eating my lunch cost wise..
Reply:i got a 25lb spool adapter for my lincoln on ebay...idk if that helps any-NateMiller Trailblazer 302gMiller Spoolmatic 30aLN-25 x 2Idealarc SP200Hypertherm Powermax 600
Reply:i think i got mine at home depot formy lincoln weld pac
Reply:This should work.:http://www.buyweld.com/m15445-1.htmlThe spindle can barely stand 10 pounds hanging on it , so try not to drop the welder or haul it down rough roads with the wire in it.
Reply:Hey krazibar,Here's the post I did a while back with the mod I did on my 151 to take the 10lb spools. Hope this may help you.Dennyhttp://weldingweb.com/vbb/showthread.php?t=16750Complete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Thanks for the advice everyone. Anyone of them will to the job fpr me!!!
GMT+8, 2025-12-21 20:29 , Processed in 0.091026 second(s), 18 queries .
