H Frame Guard Rail
发表于 2021-9-1 00:33:06 | 显示全部楼层 |阅读模式
Has anyone used the "H" frame from the guardrails on the highways. They are redoing the guardrails on several roads and was wondering if they were any good to use on welding projects.These are the "H" shaped pieces they press into the ground to support the curved guardrail.Thanks   kraftymate
Reply:To weld them you would have to grind off all the galvanize where you weld.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-21 21:46 , Processed in 0.103746 second(s), 18 queries .
