Best way to stick weld soup cans together?
发表于 2021-9-1 00:33:02 | 显示全部楼层 |阅读模式
If I wanted to weld some soup cans together, end to end (Stacked on top of each other), what would be the best way to do that with a 220V AC stick welder. I've got 1/16" 7014 rod, and 3/32" in 7014 and 6011. I'm thinking smallest rod, low amps would give me the smallest chance of burning through, but I'm pretty sure I'd still burn through anyway. What are soup cans made of, anyway?"To tell which polarity to use go to the bathroom and pour some water down the drain. If it runs clockwise use straight polarity. If it runs counter-clockwise use reverse polarity. Or if it just gurgles use alternating current." -RandomDave
Reply:Originally Posted by SkippiiWhat are soup cans made of, anyway?
Reply:Originally Posted by SkippiiIf I wanted to weld some soup cans together, end to end (Stacked on top of each other), what would be the best way to do that .
Reply:Take one can, put it on the bench. Take another can, put it on top of the first can. Then, weld them together. What? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by SkippiiIf I wanted to weld some soup cans together, end to end (Stacked on top of each other), what would be the best way to do that with a 220V AC stick welder. I've got 1/16" 7014 rod, and 3/32" in 7014 and 6011. I'm thinking smallest rod, low amps would give me the smallest chance of burning through, but I'm pretty sure I'd still burn through anyway. What are soup cans made of, anyway?
Reply:Heres a good thread on just this subject!http://weldingweb.com/vbb/showthread.php?t=26591#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-21 20:47 , Processed in 0.072657 second(s), 18 queries .
