Profax tig pedal - Miller
发表于 2021-9-1 00:33:01 | 显示全部楼层 |阅读模式
thinking of buying a profax tig pedal, anyone know how these compare to the miller HD pedals, it;s about a 40 dollar difference is allThanks!Miller Syncrowave 351, PC-300, WP18 Torch, Tec Spot Torch, Stick Hypertherm P/M 1000, 4*8 cnc plasma/router tablemiller 12vs extreme - might sell after 350pThe next lines left empty for more tools, P.S. Don't tell the wife
Reply:check out ssc controls on ebay. i've got one for my maxstar and think it's great. a helluva lot cheaper than a miller too
Reply:Originally Posted by kezgincheck out ssc controls on ebay. i've got one for my maxstar and think it's great. a helluva lot cheaper than a miller too
Reply:We run Profax MIG guns on our suitcase welders.  They hold up well and are made in USA.
Reply:I have the Profa MFC-14 it is a beast. It is made of 11 ga steel I think or thicker. Mine has taken a beating and keeps on ticking and when I got mine it was much cheaper then a Miller (ebay). I would get another one with out and second thought if that means anything, But do check out the SSC controls too, never owned one but I have read enough good things about them. -DanOwnerDW Metalworks LLCMiller Trailblazer 302Miller 8RC FeederMiller Passport PlusMiller Dynasty 200 DX W/Coolmate 1Hobart Handler 135Hypertherm PowerMAX 30Smith O/A Torch SetPlus much much more
Reply:The SSC pedals are indeed good.  I have 2 and am happy with both.  Cost about $150 each, one for my XMT and another for my TA.Check out www.ssccontrols.com, or you can get them at www.arc-zone.com.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I've got two of the Profax pedals and you could use them as wheel chocks. The only problem I ever had with one was a loose screw inside on the mechanism. It was easily fixed. I no longer pick up the pedal and put it on the machine at the end of the day like I did with the Miller. I just don't see any way the Profax could get damaged.- AndySyncrowave 250 w/coolerMM 252Ancient Century 160Victor Journeyman O/A
Reply:Well it sure sounds like it is worth saving the 35-40 dollars! Thanks for all the input!Miller Syncrowave 351, PC-300, WP18 Torch, Tec Spot Torch, Stick Hypertherm P/M 1000, 4*8 cnc plasma/router tablemiller 12vs extreme - might sell after 350pThe next lines left empty for more tools, P.S. Don't tell the wife
Reply:I have a profax pedal and a miller HD pedal. The profax is more ergonomic and more comfortable to use. So the miller sits on the shelf.
Reply:Originally Posted by lectrician1I have a profax pedal and a miller HD pedal. The profax is more ergonomic and more comfortable to use. So the miller sits on the shelf.
Reply:I am going to sell my econotig soon and I would like to include the miller pedal in the deal.
Reply:Originally Posted by lectrician1I am going to sell my econotig soon and I would like to include the miller pedal in the deal.
GMT+8, 2025-12-21 22:34 , Processed in 0.183419 second(s), 18 queries .
