Need advice from the Vets....
发表于 2021-9-1 00:32:59 | 显示全部楼层 |阅读模式
Im getting a new AD helmet. I have a Gold passive that I can see worlds better with than the plain lens.I want an AD for general use, and keep the passive for overhead or really tight places.Speedglas or Jackson NexGen are the two I have narrowed it to. A co-worker has the Digital Elite, Im not blown away by it.Ive used two different Speedglas lids, cant remember their models though.90% of what Ill be doing is pipe/stick welding. Can anybody comment on the NexGen as far as speed? Clarity? The Speedglas was nice, but older and abused, so I imagine a new lid would be a little nicer.Also liked the ventilation the Speedglas has, but it gets plenty cold up here in the winter and the 3M website says something about reduced reaction time under 23 degrees.Thanks, MaxLincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:I don't know about the NexGen specificaly, but I like Jackson hoods and lenses in general.  I have two ECQ Pro Variable lenses that have served me well that I'm quite happy with.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I use a Speedglas 9002, variable shade with the big window. Its 4 years old and its great. From what I hear from the guys that also use the Nexgen, they prefer the Speedglass because of the ventilation helps it not to fog up so bad in cold whether and it is a bit lighter than the Nexgen. A friend recently purchased the same hood I have and I can tell you it is much clearer than my 4 year old same model hood. I am also not impressed with the Miller Elites. I have not found the hood to make me want to spend 300 to replace the one I have except maybe the newer version. I am also a pipe welder and use mine to tig and stick.Good luck in your search.UA Local 598
Reply:Madmax I see in your sig you have a HF helmet. No good?
Reply:Originally Posted by 2rodsMadmax I see in your sig you have a HF helmet. No good?
Reply:Optrel?200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:too much. I hear good things, but the external controls drive me awayLincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:i have a northern tool ad i used in school then i bought a miller performance  i really like it especially fitted for my magnifiersmiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:well, wore a 9002X tonight for 4 hrs. Went back to Goldie.My eyes got really fatigued, not sure if it was the lens or the small helmet allowing arc light in from the perimeter. Looks like NexGen in a big lid for me...Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:i had the first ad jackson it lasted over 13 yearsnow i have a miller elite i like it
GMT+8, 2025-12-21 21:10 , Processed in 0.086345 second(s), 18 queries .
