New Teeth For An Excavator
发表于 2021-9-1 00:32:55 | 显示全部楼层 |阅读模式
Just new teeth and shanks, and a few wear plates. I would have done alot more but this is all the customer wanted.http://i94.photobucket.com/albums/l1...welding010.jpghttp://i94.photobucket.com/albums/l1...welding009.jpg http://i94.photobucket.com/albums/l1...welding008.jpghttp://i94.photobucket.com/albums/l1...welding007.jpgLast edited by TozziWelding; 02-27-2007 at 05:34 PM.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingJust new teeth and shanks, and a few wear plates. The company is cheap and this is all they wanted.
Reply:Big stuff...I see 2 small wear plates on the left and right side...in the middle. The teeth are very obvious...almost look too big for the bucket. Are they for a bigger unit?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:It was late on a Fri when I got the call for the job. The teeth were wayyyy to big for the bucket(they should go on a PC300, PC400 not a PC150), but the man in charge did not want to wait for the proper ones and said, "Just put them on, we need the machine for Mon". So not being one to talk myself out of work I did as the customer asked. They also had me put a few chauky bars on the side of the bucket, the old bolt on plates stayed and all I added in that area were the small weld on ones above them.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:That's ok...... by putting those ovesized teeth you will probably end up repairing the cutting edge after they spring it away from the sides.... the teeth are too long and this tends to create a lot more stress on the edge and sides when trying to pry stuff with the bucket.... especially on the outside teeth. I'll be suprised if something doesn't give out._________________Chris
Reply:Yummy.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:This is big stuff check it out! Attached Images
Reply:Good lord, yes that's some big equipment! Cool pics!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by Dipper Welder64This is big stuff check it out!
Reply:I was wondering where all the toys from my sandbox went!!!!! "Every choice you make will effect at least one other person"
Reply:I was curious what kind of wear plates you put on that bucket? Were to you go about getting them?thanks,adam
Reply:http://www.triconmetals.com/http://www.fordsteel.com/index.htmhttp://www.leongjin.com.sg/hardox.htmhttp://www.escocorp.com/
GMT+8, 2025-12-21 20:52 , Processed in 0.108697 second(s), 18 queries .
