scrollers
发表于 2021-9-1 00:32:53 | 显示全部楼层 |阅读模式
does anyone have any plans for building a scroller? pics?
Reply:Do you mean a scroll bender?http://all-a-cart.comWelding Cart Kits and accessories
Reply:yeah on for bending flat and round bar
Reply:Hmm...I haven't seen one but would be interested. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Like this?http://all-a-cart.comWelding Cart Kits and accessories
Reply:yeah thats what i was talking about, i would like to build on of those
Reply:I know that people have talked about them on here but I'm not sure of anybody has built one from scratch.Let me do some checking and see.....http://all-a-cart.comWelding Cart Kits and accessories
Reply:Here is a link to one topic on here that provided some ideas and other links for scroll benders....Hope this helps.http://www.weldingweb.com/vbb/showthread...=scroll+bender- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:ok, thanks, any help would be greatly appreciated!
Reply:I haven't seen one built yet either. I'll have to check that link. IMO, probably cheaper to buy and save time/money.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:What size stock do you want to bend?  The bender pictured above only bends 3/16 flat bar and 1/4 in round.  Do you just want to build a scroll bender? Though if you need a scroll bender and  if you are going to bend stock within the capacity of the scroll bender, then I would buy one.Usually for heavier stock--the material is heated and bent around a fixed pattern.  I started this thread last year.  It might be helpful, if want to make a pattern.   http://www.weldingweb.com/vbb/showthread.php?t=5190
Reply:I have bent 1/2 " round bar with my HF bender.  The HF scroller needs some work on the scroller to ger good scrolls.  The end of the inner die has a flat spot.  If you build it up with some weld and regrind the proper profile it will make pretty decent scrolls.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Thanks for the info everyone, that was extremely usefull info taqpwelder, i never thought of it that way.
Reply:Are you looking for a particular size scroll? What material thickness? I have made homemade scroll jigs that start with a "donor' scroll, I will post some pics within a couple of days.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:I have the Shop Outfitters scroller and it is first class, but it takes a toll on the body when making alot of scrolls. So i put a 3/4 hp motor and a 60:1 gearbox on mine. 1,000 scrolls a day are possible and its all sweat free...BobPICS>>> http://new.photos.yahoo.com/aametalm...60762312603743Bob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
GMT+8, 2025-12-21 20:52 , Processed in 0.086240 second(s), 18 queries .
