rust and corrosion
发表于 2021-9-1 00:32:46 | 显示全部楼层 |阅读模式
I thought I would post this picture of a broken barge spud.  It is about three feet square on the end and full length about sixty feet long. There was a cross brace next to the fracture however it has long ago rusted away.  Of course we are going to repair this.  Who said you couldn't weld iron oxide ???  Sometimes one has to compromise.  The world is not perfect. Attached Images
Reply:What - no dime or soda can for comparison?  Very cool big stuff Lo, thanks for the pic!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:looks like its got 2 layers like a sleeve inside.  Is it possible to resleeve something like that?  I see a seam running down the length of the outer piece.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:It was 3/8 plate formed in a channel then welded into a tube.  Angles were then welded on the corners.  To splice back together the ends are cut back square and and quarter inch thick backing bar tacked inside the butt joint.  The angles are cut back and replaced so that the replacement angles overlap the joint.
Reply:Pretty cool Randy. Post a pic of the completed job. The dime would have been nice as john suggested for comparrison as in the picture it dosn't look that big.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Glad to see I'm not the only one who has to deal with the junk that goes to sea. I just did some mods to a few spuds._________________Chris
Reply:Here is some of the repairs.  Since all the cross bracing was gone inside and no one wanted to crawl in we cut openings and bracing was inserted then the openings were welded up again.  I didn't have the personal experience of this repair.  It was a mighty dirty job.  The gas shielded flux core was ideal for fusing into the rusty walls.  Sorry the one pic is quite dark.  I am not used to this new camera.  I am finding my old Mavica is tough to beat. Attached Images
GMT+8, 2025-12-21 20:55 , Processed in 0.096681 second(s), 18 queries .
