Transformer wall mount
发表于 2021-9-1 00:32:45 | 显示全部楼层 |阅读模式
Built this todayTrailblazer 302 AirpakDynasty 200 DX  Thermal Dynamics Cutmaster 52 CamoMiller Dailarc 250 OLD But great!!2 Miller 140's w/autoset NEW! Millwauke Cold cut sawsDewalt portabandJd2 notcherPipe beveling machine
Reply:Very nice, good job man.... although it can use some paint -Clarke 130EN-Miller MaxStar 150STL-Miller Elite 29' Roadster
Reply:Straight..even..nice job..Besides the pre mentioned paint..Next time loose the weld spatter and the smoke discoloration first..  Cosmetics and a nice job go hand in hand.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:My boss took the picture while as was at lunch I will post CLEAN pics after its paintedTrailblazer 302 AirpakDynasty 200 DX  Thermal Dynamics Cutmaster 52 CamoMiller Dailarc 250 OLD But great!!2 Miller 140's w/autoset NEW! Millwauke Cold cut sawsDewalt portabandJd2 notcherPipe beveling machine
Reply:Originally Posted by FluxMy boss took the picture while as was at lunch I will post CLEAN pics after its painted
Reply:Nice place to install that transformer. I've work in places that floor mounted them and they become junk collectors.
Reply:Real nice job. Looks to be so you can even get to the transformer for inspectionand service if need be.[b]I will say that I shudder when I see setups like this without details on the tie-in to the wall. Transformers are heavy, and I have seen several mounts in this style fracture the wall or outright pull out (in one case an HVAC heat exchanger, directly over my, and my students, heads). Block walls are relatively fragile to loads out of plane, and heavy loads need to be hung carefully.So how is the bracket attached?
Reply:I thought someone would ask  It is through bolted through the doulbe wide block wall with a 4'x4'x 1/4" backing plate on the other side. Inspector came by and approved after lunchTrailblazer 302 AirpakDynasty 200 DX  Thermal Dynamics Cutmaster 52 CamoMiller Dailarc 250 OLD But great!!2 Miller 140's w/autoset NEW! Millwauke Cold cut sawsDewalt portabandJd2 notcherPipe beveling machine
Reply:That makes me feel better. Walking into a room and finding several hundred pounds of heat exchanger on the floor roughly where you were standing less than an hour before kinda make you think about this
Reply:Looks good flux.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:The mount looks good. Don't listen to Zap, he is a much better talker than a welder. Look at his projects. Most of them look like a robot bird flew over his shop and crapped on a peice of metal he was working on.
Reply:Originally Posted by TIGMASTER9000The mount looks good. Don't listen to Zap, he is a much better talker than a welder. Look at his projects. Most of them look like a robot bird flew over his shop and crapped on a peice of metal he was working on.
Reply:Can we nuke this guy?"POOF" you should be gone.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RCan we nuke this guy?"POOF" you should be gone.David
GMT+8, 2025-12-21 20:49 , Processed in 0.101659 second(s), 18 queries .
