here is some pics of the trailer cage i am making. Attached Images
Reply:more ............... Attached Images
Reply:What process are you using? Seems a bit excessive on the spatter._________________Chris
Reply:.030 fluxcore 110 mig. before i paint it i will take all the spatter off with the grinder.
Reply:Last time I had spatter llike that, I had polarity wrong. Fluxcore needs Electrode negative.DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:well what is it, flux or mix, im sure its flux, yea, did you reverse the polarity inside the welder, also, you should be using .035 wire for welding like this |
