.040 Sheet Aluminum To .125 Angle Using 1/16 Filler..
发表于 2021-9-1 00:32:44 | 显示全部楼层 |阅读模式
Welded up a Aluminum panel for wog820's train set electronics..We have said many times you need filler smaller than the base material..But with only 1/16 in hand heres a method to overcome such situations..I could have welded the plate to the angle on the edge..But it would have made more of a mess than this way..Move the rail in so you have about 1/8" Of base mat. "hanging out"That way there you can use it as filler and then you only have to "dip" filler every so often..Sorta like fusing but diffrent..Thats about all you can do when you run across this delemma..And it will work with most any Steel/Aluminum thin sheet..I get all the fun jobs..  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Great Idea!Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Good job. What's next? Welding a beer can to a battleship.
Reply:Originally Posted by tresiGood job. What's next? Welding a beer can to a battleship.
GMT+8, 2025-12-21 20:52 , Processed in 0.280087 second(s), 18 queries .
