Todays Weldment..With A Little "Gussett 101" Thrown In For Laffs..
发表于 2021-9-1 00:32:43 | 显示全部楼层 |阅读模式
Had to go in this A.M. and put a weldment together so it can be machined first thing monday..Here is the mock-up..Now....about those gussetts...This is not the way we do it..This is more like it...As you can see I lost the corner..You should do that to every one because you can't weld into..or out of a corner..Its a waste of time just trying..So don't bother.. So now its on to the tacking..Rule 1..Measure and re-measure all your dimentions..Now tack it..After tacking recheck all the dimentions!!You have no idea how much fun it is to get apart once its finish welded if there is an error.. Next post has the finished results.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ok now we're all done!And by the way...We don't have any vending machines in the shop..So it's still the same dime.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Just curious, whats the part for?Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:that is pretty thick steel, just curious why it was tig welded?but those are some sweet beads!
Reply:Originally Posted by steve28that is pretty thick steel, just curious why it was tig welded?
Reply:alright... my boss won't let us tig anything over 1/4" they say it's time consuming, but alot less clean up!Last edited by steve28; 03-24-2007 at 11:30 AM.
Reply:Originally Posted by zapsterBetter than a mig..or stick..anyday  ...zap
Reply:distortion or did you clamp the weldment to try and control that? Also what you were running for parameters?
Reply:Why not run the bead through the notch?  Just not necessary?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:metal is my future
Reply:Originally Posted by DoolittleWhy not run the bead through the notch?  Just not necessary?
Reply:Originally Posted by zapsterI've been doing this waaaay too long... Welder on..Gas on..Water on..Mask down..One glove..1 Hr and 20 mins later...  ...zap!
Reply:Originally Posted by banshee35U THINK u are the god of welding don't you!you could have taked w/a 5p and used a 7024 or a 7018 and been done in 10 min or so.
Reply:U THINK u are the god of welding don't you!
Reply:Welding Gussets?  I do em all day These were 48"  I used a mig and the job still took 47 hours.  18 of em, 3/4".  On windy days I had to stick em with 5/32 7018.  I don't think you can see, but the corners are cut out too.Not as pretty as Mr. Zap, but it paid for most of my Ranger 250.And YES I could bend em pretty good if I didn't alternate sides of the gussets as I went up.David Attached ImagesLast edited by David R; 03-24-2007 at 07:04 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:^^^^^^ Thats some cool stuff right there. You get all the fun jobs... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Everybody knows I am the GOD of welding!!  Bill
Reply:Originally Posted by WHughesEverybody knows I am the GOD of welding!!  Bill
Reply:BTW, thats very nice work Zap. I haven't done ANY welding all week.Bill
Reply:Originally Posted by WHughesBTW, thats very nice work Zap. I haven't done ANY welding all week.Bill
Reply:Very nice. And good explanation on why you didn't run through the notch.I'm spendng way too much time in the office and doing other maintainance anymore..... I'm out of practice. Never was a welding god, Not even a welding junkyard dog at this point.
Reply:I'm out of practice. Never was a welding god, Not even a welding junkyard dog at this point.
Reply:Nice work as usual, but I'd really like to know more about what that thing is for. I can't think of a reson that something mounted with 10-32 screws would need to be mounted to a gussetted 1/2" peice like that.One other thing about doing gussetts like that. In thinner material like a bike frame, by not welding it all the way it allows a little movement so that in a shock load it will just flex a little instead of cracking. I don't think that thing is going to flex much, but had you been welding 24ga it would come into play.
Reply:but had you been welding 24ga it would come into play.Originally Posted by chopper5hope that was a joke because it was an unnecessary comment
Reply:Nice work man.
Reply:Originally Posted by banshee35yes i was trying to be comical. no offense  to ya zap. I'll post pics of my piping runs when i can. the refinery i work at doesn't allow us to have cell phones or cameras because they aren't explosion proof. When I get back to the shop I'll take some.
Reply:Originally Posted by maxyedorSo they are worried that a weldor mite light something on fire with their camera
Reply:I believe maxy was pointing out the apparently idiotic 'safety' rule of no cell phones or cameras because of the slight chance of a tiny spark from the electronic device, when we are talking about welders at the same place making large arcs, sparks, and molten metal on purpose.And yeah, zap does like his TIG.That 1/2 inch thick metal may be being used with only 10-32 screws because they want the piece to be beefy and solid and not vibrate or move.  Or maybe they are going to stick weld the 25 HP 3-phase motor onto the top of it.  Or someone typoed a hole or thread call out somewhere (guy at customer: 10-32 holes?  They're supposed to be 1-8 and 2 of them!  Smudge the 8 a bit and it can look like a 3, then mush the 2-places call-out too close and you have what looks like a 1blur-32 so it must be a 10-32.)Match the tool and task for the job needed.  Some tasks or job requirements may need all edges and seams and possible foreign-material or FOOD or process-material trap-points to to welded completely and smoothly.  In which case one might have to jig or fixture the 'main' upright in place and weld it fully to the base plate, then make a small corner notch on the gusset to just clear the main fillet weld, and then weld the gusset in place and fill in the notch as well.  Or the part may have to meet critical fatigue life specs and all weld discontinuties (like undercut, or craters, or starts or stops) would have to be eliminated to minimize crack initiation or propagation points.It all depends on the needs of the job/project.It's also probably why there was no call-out or need for a double-bevel 100% penetration weld, the relatively small fillet is enough for the service of the part.Hey zap, out of curiousity and since we're asking you questions, about how much penetration do you estimate you got on that 1/2 inch plate?  About 1/8 inch on each side?  Just asking.
Reply:[When its tacked in the right place and in the right order...Distortion can be eliminated...that place and order....Is that just best judgement left top, right bottom etc...
Reply:Hey zap, out of curiousity and since we're asking you questions, about how much penetration do you estimate you got on that 1/2 inch plate? About 1/8 inch on each side? Just asking.
Reply:Ok, so the welds are beautiful as they always are  But what I don't understand is why you don't weld into the corners.  At the last job I had, it was an expectation for us to weld (Mig, Tig on both steel and aluminum) inside corners.
Reply:Originally Posted by weldrwomnOk, so the welds are beautiful as they always are  But what I don't understand is why you don't weld into the corners.  At the last job I had, it was an expectation for us to weld (Mig, Tig on both steel and aluminum) inside corners.
Reply:Leaving the corner out also helps prevent water from accumulating and causing the assembly to rust out.
Reply:You are correct! I am laughing at your welds right now. My advice to you would be to practice.
Reply:Originally Posted by TIGMASTER9000You are correct! I am laughing at your welds right now. My advice to you would be to practice.
Reply:Nice fillet size. A good welder could weld into the corner. I am not ragging on you, not everybody is fit to weld. Some people can do it and some people can't. Just keep it up, you may be able to do it someday!!! Mcdonalds may have a fry cook position available.
Reply:TIGMASTER9000, if you don't have anything constructive to say or add to this forum then don't post.http://all-a-cart.comWelding Cart Kits and accessories
Reply:I was just letting Zap know that he should not rag on welds that look better than his. You do great work. I would take advice from you. Taking advice from him is like asking a mute to tell you the meaning of life.
Reply:Originally Posted by TIGMASTER9000I was just letting Zap know that he should not rag on welds that look better than his. You do great work. I would take advice from you. Taking advice from him is like asking a mute to tell you the meaning of life.
Reply:What are the requirements for teaching? In the Tig classes I have taken, you would get about a "C".  Now that you are done replying messages to me you will have time to practice! Practice makes perfect! I have proven my point!
Reply:The only point you have proven to anyone here is how much of an a$$ hole you are..Not even 10 posts yet and all you do is rag on me..For all we know your just a bozo with nothing better to do..I'll even bet you were here before as someone else..the authorities are looking into you right now..You will not last long here..Trust usLike I said..PUT UP OR SHUT UP.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:This thread will remain locked until a certain issue can be dealt with.Sorry for the inconvenience.- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Just a note from the Eye in the Sky:Not everybody is going to like each other here, and if you want to toss around the occasional insult, that's up to you. But I will not let this site devolve into a flame-war cesspool -- and this thread is quickly moving in that direction. That's the only warning.The thread has been reopened. The next posts need to be on-topic.Bob RosenbaumFormer PublisherPenton's WELDING Magazine
Reply:hope this is on topic...and i  rag no one..jsut an observation..in the  fab  shop at the  company i work  for (steel fabrication)  all gussets  are  cut and fit to weld  100 %  the  only time there is an acception is when the item  being fabbed is  going to be  galvanized and the draftman (women) ask for a weep hole  for  the  galvanizing to  run throughif  this is  different on  alum. or  ss i wouldnt know
Reply:nice welds there zap.. i have some aluminum welds at work which absolutely must be welding in an inside corner cause of the type of extrusion (i'll try to make a picture) but i was just wonder what you thought about thathttp://specific.net
Reply:k here are my pics.. they're sort of difficult to understand since i didn't spend much time on them but i hope someone can understand http://specific.net
Reply:Originally Posted by MoonRiseI believe maxy was pointing out the apparently idiotic 'safety' rule of no cell phones or cameras because of the slight chance of a tiny spark from the electronic device, when we are talking about welders at the same place making large arcs, sparks, and molten metal on purpose.
Reply:As for Zap, I'm a little dissapointed man. Where are the pictures of the parts you make in use? You "get all the fun jobs", and can lay down a great bead, but whatever this weldment was for has to be at least a little bit cool to look at, share the fun
GMT+8, 2025-12-21 22:32 , Processed in 0.095945 second(s), 18 queries .
