repair on a grinder
发表于 2021-9-1 00:32:38 | 显示全部楼层 |阅读模式
if i have used a grinder on a dc welder and the grinder is ac can it be repaired
Reply:what kind of grinder is it, most grinders use brushes which makes them ok to use with d.c
Reply:dewalt
Reply:ok more details are needed? you pluged it in on your sa200 then it ran for a bit then started smoking, blew up etc? then you tried running it on ac and it didnt work at all? did you have your machine reved up, what type of sa200 do you have age wise?
Reply:My dewalts work great off of DC
Reply:Using a grinder with a variable speed switch will burn out the switch if used on DCI always tried to work with the oldest hand on the job to gain knowlege but now I can't find any.
Reply:I have replaced switches with in line lamp switches from time to time in a pinch.I always tried to work with the oldest hand on the job to gain knowlege but now I can't find any.
GMT+8, 2025-12-21 22:33 , Processed in 0.096230 second(s), 18 queries .
