ac / dc
发表于 2021-9-1 00:32:37 | 显示全部楼层 |阅读模式
I have a sa 200 but as you know its dc only i have grinders i would like to use on it thats ac, i would like to know what i can do to make them work on this machine
Reply:The DC represents welding current."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:i know what dc mean thats not what im asking
Reply:No; The welding current is DC only. The accessory outlets are A/C as far as I know.
Reply:the sa 200 plug outlet is d.c. current, that is what he is asking about! anyways anything with brushes and is lower amprage will work i think it is 8 amps or soo dont quote me on that exact number i run grinders and drills etc on mine all the time, also my sa200 has a pin that i have to put in to keep the idler reved up
Reply:Originally Posted by papabearThe DC represents welding current.
Reply:Originally Posted by bosshogg713I have a sa 200 but as you know its dc only i have grinders i would like to use on it thats ac, i would like to know what i can do to make them work on this machine
Reply:what about buying a big power inverter and hook on the  machine
Reply:there is a way to do it if you have the right alternator
Reply:You can use a grinder as long as it doesn't have a variable speed switch on it, if it does it will fry the switch.I always tried to work with the oldest hand on the job to gain knowlege but now I can't find any.
Reply:Buy a Bobcat and mount it next to the SA.  You'll have the nice stick welding arc of the SA and the 10KW of genny power from the Bobcat to run whatever tools or other machines you want to run.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Buy a Bobcat and mount it next to the SA.  You'll have the nice stick welding arc of the SA and the 10KW of genny power from the Bobcat to run whatever tools or other machines you want to run.
GMT+8, 2025-12-21 21:06 , Processed in 0.093665 second(s), 18 queries .
