I have a friend that asked me if I could weld his brushhogBlade. Seems it broke dead center on either side of theShaft hole.Figured I'd ask you guys first before I told him yes....G.
Reply:I have welded a new edge on a dull blade that is strong and NOT BROKEN, I would not weld back together a broken blade..go to tractor supply and for under $50.00 you can get a new blade....its cheap insurance..when you hit that rock and the weld lets loose whose gonna get whacked with the flying blade..
Reply:If a flying BH blade were to hit someone it would be bad so welding up the mounting hole would not be worth the risk as mentioned by everyone.Now building up a worn cutting edge would be fine.
Reply:I wouldn't want anything to do with that either. BrushHogs are supposed to have a shear pin in the drive line so that they don't break blades and for that to have happened tells me that he probably has a regular hardened bolt in the PTO shaft, so the next time he breaks a blade I would just as soon he does it on a blade that I haven't touched.
Reply:NEVER EVER WELD a rotary cutter blade. They will break and tear through the top or side of the cutter and keep flying for a 100 yards. Some are heat treated as well.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:A brush hog blade weights 20 to 25 lbs and will be thrown at more than 100 mph. Than there is the mater of the other blade, with the imbalance caused by one blade the whole brush hog will buck like a bronco. If the blade split, there are some serious metal problems. You are just begging for trouble as others point out.
Reply:Seems like a good way to lose a friend.Matt
Reply:Seems like it's been covered pretty well.I won't go further.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Thanks Guys!!! That is why I asked....I stopped by the local tractor supply co. and picked him up a new blade.It was a lot easier than the alternative.G. |
