Little Sawhorse Project
发表于 2021-9-1 00:32:22 | 显示全部楼层 |阅读模式
Check out the "little" sawhorse project we just finished. Attached Images
Reply:Hmm.  Now what will they be sawing on those horses?Looks like it would hold a freight train . . . with a truck on top . . . loaded with pianos!Nice work.
Reply:Must be a pretty big dollhouse! "Every choice you make will effect at least one other person"
Reply:These are designed to support the front end of a Cat 793 Mining Truck while the front tires are changed.  Aprox weight of truck front end is 90 tons, stand is rated for 140 tons.
Reply:Very big saw horses...cool! How was the design completed? Mining engineer?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by rednekinazThese are designed to support the front end of a Cat 793 Mining Truck while the front tires are changed.  Aprox weight of truck front end is 90 tons, stand is rated for 140 tons.
Reply:Micro, you are correct.  The mine contracted with their global engineering firm for the design-specification work.  We just got to build the sucker.
Reply:geez, what's the material?  Dimensions?  Looks huge.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:10 x 6 x 1/2 wall A500 Grade B for legs & top rail6 x 6 x 1/4 wall A500 Grade B for bottom beam & cross braces6' tall x 9.5' wide
GMT+8, 2025-12-21 20:52 , Processed in 0.070900 second(s), 18 queries .
