So I Was Board Today..
发表于 2021-9-1 00:32:21 | 显示全部楼层 |阅读模式
Had a little fun with some 7018...I allmost forgot how much fun it is!!  Gotta get ready for school.. Just some 1/4 X 1" Stock with hand grinder bevels in them..Root pass horizontal..Cover pass before chipping..Cover after chipping..And for laffs after I put it in a vice and did a vert. down pass on the other side..1/8 7018..160 amps D.C.+Never touched the machine..Do I pass??I'll do better next time .. Its been a few years.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:A+ zap.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:I figured I'd give youz guyz something to   at..But NO..Can't even do that right..  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Now for a verticle up?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:ver. down?  why down
Reply:looks good  there  ZAP... so  did it bring back the old days????
Reply:Well.... no need for me to show up on Sat..._________________Chris
Reply:Originally Posted by David RNow for a verticle up?David
Reply:Originally Posted by infamousjerver. down?  why down
Reply:Originally Posted by lorenzoWell.... no need for me to show up on Sat...
Reply:Ok, looks good, now it's time for 6010 over head with a weave cap please
Reply:Originally Posted by bigcountry1009Ok, looks good, now it's time for 6010 over head with a weave cap please
Reply:ATTA-BOY zap!.....Thank you for the Vert-Down-7018.....Yo know what "They" say about 7018 vert-down.....But.....How come in that last picture.....The little "U" shaped ripples are pointed in the direction they are?Patrick
Reply:Originally Posted by Sober_PollockATTA-BOY zap!.....Thank you for the Vert-Down-7018.....Yo know what "They" say about 7018 vert-down.....But.....How come in that last picture.....The little "U" shaped ripples are pointed in the direction they are?
Reply:I'd say 160 amps is a lot of heat for 1/4" plate and 1/8 rod, that's what I'd say!
Reply:Originally Posted by SupeI'd say 160 amps is a lot of heat for 1/4" plate and 1/8 rod, that's what I'd say!
Reply:Looking good, verticle up is all about keeping the right rod angle.
Reply:Originally Posted by zapster200 feet of cable......zap!
Reply:Originally Posted by TEKStill a bit much for 1/8.
Reply:I still think 160 is too hot even with the 200' cables
Reply:I was just messin' with ya.....It looks like you flipped it over before you took the picture.....That would make it look Vert-up instead of Vert-down.....I think the Vertical Down Drag looks pretty good for a procedure I've heard a lot of people say can't be done!..........(with 7018)Patrick
Reply:Wait... I take back my first post I'm not there doing the work I don't know what machine it is? or What other factors come into play If zap says 160 he should know he's doing the work not me
Reply:Vertical down with 7018 has an advantage, it's fast (you've got to stay ahead of the slag).  It doesn't put as much heat into the metal as a vertical up.  From an asthetics standpoint, my vertical down welds look better (exactly the same as my horizontal welds).
Reply:Here is a vertical up I did the other day after I got my new TB-302. Really smooth machine. 3/32 7018 @ 80 amps 1/4" plate. Attached Images
GMT+8, 2025-12-21 20:51 , Processed in 0.090614 second(s), 18 queries .
