Cutting tube/pipe length wise...pics
发表于 2021-9-1 00:32:21 | 显示全部楼层 |阅读模式
I am making stringer support plates for my Big Block Chevy Nordic Jet Boat. I am making stringer support plates for the through bolts. The tops of the stringers are radiused so I had to find the radius and found some pipe that matches the radius. I then had to cut the pipe down the center length wise. So here is a trick, tack some flat stock to act as a guide (see pics).This worked out great. I was going to weld the plates to the pipe but I was out of filler. More pics when I progress.T.J. to see more pics of the boat project go to my site.www.tjsperformance.com
GMT+8, 2025-12-21 20:52 , Processed in 0.070647 second(s), 18 queries .
