Small Enough Tig Welding..
发表于 2021-9-1 00:32:19 | 显示全部楼层 |阅读模式
Got some parts in this A.M. that needed to be welded..But there was a catch..They were case hardned before hand... And were rather small in the weld area..So what you do here is loose the hardned metal before you weld it..Did'nt get any pics of the actual process but this is what you do if you ever encounter this problem..Wherever the parts are gonna be welded.. mark the area on both pieces with a marker..Mock them up..Do your marking...Only remove the hardness with a hand grinder from that area..Then proceed with the welding...Like I said.. this was small stuff..The last one is just very small welds in the corners above the dime..I get all the fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Very nice, some small stuff. What did you use for wire ?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneVery nice, some small stuff. What did you use for wire ?
Reply:Cool info zap, btw, Ive got some thomson shaft (RC60 hardness) that I want to drill a 1/4 inch hole in.  Can I grind the surface a bit so I can get the bit through?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by DoolittleCool info zap, btw, Ive got some thomson shaft (RC60 hardness) that I want to drill a 1/4 inch hole in.  Can I grind the surface a bit so I can get the bit through?
GMT+8, 2025-12-21 20:51 , Processed in 0.086740 second(s), 18 queries .
