homemade positioner on the cheap
发表于 2021-9-1 00:32:18 | 显示全部楼层 |阅读模式
I was wondering if anyone has ever attempted anything like this on the cheap.  I am not attempting to make anything complicated or anything that would hold alot of weight.  I got the idea of using the circular ball bearing cage from a lazy susan my wife had.  Then I thought well if I could find a large diameter bearing (I.E. Wheel bearing) maybe I could sandwhich that between two plates to make something that rotates.  What I am trying to accomplish is the welding of pipe to a plate.  The trick is is that the welds between the plate and pipe need to look good.  I was thinking if I could build it on the cheap I could have a friend spin (slowly of course) the unit while I welded....  Again these are just thoughts but as usual I will welcome any thoughts or ideas.  Thanks,Chris
Reply:maybe use a electric can opener with a belt and pulley ?
Reply:A member on here just completed one. Run a search and you'll find it. He documented it really well.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-21 20:56 , Processed in 0.361929 second(s), 18 queries .
