Hardfacing electrodes
发表于 2021-9-1 00:32:18 | 显示全部楼层 |阅读模式
Any suggestions on what electrode to use for hardfacing excavator buckets with a DC stick machine?
Reply:stoody rod, I use 31 or 35thermal arc mst400, va4000 feeder, lincoln 175 min, victor torches, miller s32p feeder, air arc k4000 for work.
Reply:Originally Posted by adam21584stoody rod, I use 31 or 35
Reply:Any good/bad experience with McKay Hardalloy 140?
Reply:i have been using Hardmelt 600, mainly cause that is all that is available over here and it takes 90 days to get anything shipped in.  It's not perfect but works OK.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:I was gonna say Linc-core55 but you did specify stick---I've burnt a lot of Stoody 36...
Reply:Originally Posted by DEMAny good/bad experience with McKay Hardalloy 140?
Reply:Originally Posted by DEMDoes stoody 31 hold up ok for bucket edge and teeth in rocky soil or do I need to step up to 35?
Reply:I've met with success using InWeld HF961 for metal abrasion resistance on steel conveyor lines.CWI, CWE, CST for Miller, Lincoln, Thermadyne, Hypertherm & ESABMillermatic 350PLincoln Invertec 205 AC/DCVictor combo torchESAB PCM 1125
Reply:Originally Posted by TEKGo to the Stoody website and check their FAQ sheet---they make application specific rods and they will tell you what goes where...
Reply:either one will workthermal arc mst400, va4000 feeder, lincoln 175 min, victor torches, miller s32p feeder, air arc k4000 for work.
Reply:Tried Stoody 31. It burns amazingly smooth! And slug peels on its own.
GMT+8, 2025-12-21 22:34 , Processed in 0.086800 second(s), 18 queries .
