2hp aluminum engine fix
发表于 2021-9-1 00:32:11 | 显示全部楼层 |阅读模式
My nieghbor changed the oil in his gas pressure washer engine and cracked the housing putting the plug back in too tight. Here's some pics, I can't see the pics as I post them so by memory I think it goes: crack, gouge with carbide burr, burn thru with too much amps, weld all over crack, fix melt thru and retap, finished weld. Attached ImagesMan invented metal, he can do whatever he wants with it.KMAC
Reply:Looks good -- nice fix.What process did you use?
Reply:Tigged it with my old miller gold star. I have the foot control but it doesn't control very well. No ripples cuz I had to flow everything together to get the bubbles/contaminants out and can't go low enough on the heat either, so it wanted to melt thru. Looks like I lost the last picture. Here it is. Attached ImagesMan invented metal, he can do whatever he wants with it.KMAC
GMT+8, 2025-12-21 22:03 , Processed in 0.096311 second(s), 18 queries .
