Patch in Reostat for greater control
发表于 2021-9-1 00:32:03 | 显示全部楼层 |阅读模式
Greetings, I am thinking, stop me if I'm wrong, that patching a 100watt 10 or 15 ohm Reostat into the output to the tip, [wire feed] would give control in Low mode from about 10 to 60 Amps and in High mode from 60 to 90 Amps. The unit is: 110V 90Amp wire feed.Does this sound right? I would appreciate your thoughts on the subject!Thankyou RichardLast edited by valley ranch; 05-22-2010 at 04:17 PM.
Reply:You're going to let the magic smoke out of that reostat pretty quick. 100 watt isn't anywhere near big enough to survive that.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Do you know what is needed?
GMT+8, 2025-12-21 22:03 , Processed in 0.116188 second(s), 18 queries .
