Emergency Project - Lawn mower
发表于 2021-9-1 00:32:00 | 显示全部楼层 |阅读模式
Emergency weekend project – repair my lawn mower! Sorry there’s no pictures. Digital camera? I don’ have no steekin’ digital camera!Pushing the thing up the lawn, I suddenly found the handles no longer attached to the motor assembly, which was a bit of a shock. It transpired that the bracket attaching the handles on one side had broken. Unperturbed, I dismantled it and got the buzzbox out. MIG would have been easier welding, but:1 I can’t get the mower into the garage, since the big door is jammed closed (long story, it get replaced this week);2 I’m between gas bottles and I’m too cheap to get another one since I don’t have project on at the moment.So, outdoors work with the buzzbox it was. Cleaning up the bracket revealed a nasty stress crack on the opposite side of the bracket to the break. Being suspicious, I checked the other bracket – same story. Cleaned up (grinder and wire brush), and ground out the cracks, then more cleaning (wire brush and solvent).Luckily, I could flip the mower and do all but one of the welds horizontal. The last was a vertical up. All 6013, 2.5mm (3/32” in old money I guess), at about 70-80A. After cleaning the slag off, it just needed a small amount of grinding on the (former) break to allow the handle bolt to fit. A coat of primer, then reassembly. I was back cutting in less than an hour.A small, twopenny demonstration that with the buzzbox, you don’t have to bring the work to the welder – you can bring the welder to the work! This little job earned me some nice kudos from my wife, saved a packet on two new brackets, and I was back in action in less than an hour. I defy any garden machinery repair outfit to beat THAT on a Saturday afternoon!
Reply:LOL! good story.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-21 22:06 , Processed in 0.118104 second(s), 18 queries .
